Automation- Blog Posts to WordPress
Status: Open · Asked by Hoom07 on · 0 views
Hoom07 — Question ·
I need to create an automation:
Feeding news article links in a spreadsheet (trigger) -> use perplexity/openAI to generate long form blog posts using that link/links -> then an AI-generated image should be created related to the blog post -> it should automatically post the blog post + image generate to WordPress
I dont know how to do AI-generated image part, can anyone guide on this other than that i know how to do it
Hello @Hoom07,
For the AI-generated image part, please refer to the attached tutorial link. It explains how to generate images using AI. Let us know if it helps.
youtube.com/watch?v=Sij0dhEA-qU:340
