Best way to scrape websites to generate a company overview?
Status: Open · Asked by William Mingione on · 0 views
Hi everyone! Im trying to scrape a website to generate a company overviews for our sales team and pass that information to our CRM. I see there is no way currently to do this using OpenAI's connection in Pabbly (It says it doesn't have access to the internet).
Im wondering if there is an option to use a different tool to scrape the site and then pass that info to OpenAi to generate the overview.
Would love to get some feedback! - thanks in advance
Hi @billymingione,
I’m afraid the use case you're describing is currently not possible, as we don't have an application that can help you scrape data from a website.
Hi @billymingione,I’m afraid the use case you're describing is currently not possible, as we don't have an application that can help you scrape data from a website.
Thanks @ArshilAhmad - I wound up finding something on RapidAPI that could do what I needed!
Thank you for the update. We are glad you were able to find a workaround.
