Connections got two products on Teachable workflow
Status: Open · Asked by fatboy11 on · 0 views
The idea is that at the time of enrollment it should capture the ID, but from 2 or more courses. Depending on the variable that contains the course name, it should take the correct one.
I’m testing it with a router as we saw yesterday; during enrollment it splits for the user that is already created.
But so far, I haven’t figured it out.
Hi @fatboy11,
Could you please create a short screen recording and elaborate a bit more on your exact concern? Also, kindly share the Workflow URL where you are facing this issue.
We’re running a flow from WooCommerce → Pabbly → Teachable. Our WooCommerce store has two separate products (Course 1 and Course 2), which correspond to two Teachable courses.
However, the integration is only assigning Course 1. When a customer purchases Course 2, Teachable still grants access to Course 1 instead of Course 2.
We need guidance on how to branch the workflow so that the correct Teachable course is assigned based on the specific WooCommerce product purchased (Course 1 vs. Course 2).
Workflow URL for reference: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZhMDYzNTA0M2M1MjY5NTUzZDUxM2Ii_pc
Thanks in advance!
Please disable 'Simple Response,' then click on 'Re-Capture Webhook Response' and capture a new order in WooCommerce.
Then add an Iterator to your workflow to iterate through all the line items in your orders. Map the item name to both your routes. This will ensure that each time an order is placed, all its line items are iterated. If a user purchases item 1, route 1 will be executed; if they purchase item 2, route 2 will be executed. If they purchase both items, both routes will execute. In each route, add the 'Teachable: Enroll User in Course' action step with their designated courses.
