Data Not Being Sent from Gravity Forms to Pabbly Webhook (some of entrys)
Status: Open · Asked by Bobby on · 0 views
Bobby — Question ·
Hello Support Team,
I’ve set up a webhook in Gravity Forms to send form submission data to Pabbly Connect. Most of the time the data is sent successfully, but occasionally the data does not get sent to Pabbly, and no entry appears in the workflow history.
Here are some details:
  • Form tool: Gravity Forms (Webhooks Add-on enabled)
  • Integration: Pabbly Connect via Webhook (POST / JSON)
  • The webhook URL works for most submissions.
  • The issue happens randomly — some submissions never reach Pabbly, without any visible error in Gravity Forms.
Could you please help me identify why some submissions are not being delivered and how to ensure that every submission is reliably sent?
Thank you in advance for your assistance.
See this entry is not showing in Pabbly history. If you want to change something in workflow, first ask me
Soumya Tripathi — Reply ·
Hello @kumarbobbyldh
Since this is a descriptive webhook, we capture the data sent by Gravity Forms. If you want to verify, you can use https://webhook.site/ to check whether Gravity Forms is sending the data.
For further clarification, you may also need to contact the Gravity Forms support team.
Bobby — Reply ·
ok allow me time for it
@kumarbobbyldh
Sure! Take your time.
