Document Title Issue in Broadcast Template
Status: Open · Asked by Nassar Bava on · 0 views
Nassar Bava — Question ·
I am experiencing an issue when sending broadcast templates with attached documents through Pabbly Chatflow. While sending, the document titles appear as "untitled" to my clients. However, when sending the same templates directly from the inbox, the titles display correctly. its a PDF document
Hi @nazarvbava,
Could you please state the template where you are facing this issue?
Nassar Bava — Reply ·
The issue is occurring with the broadcast WhatsApp template. Please find the attached screenshot for reference. Kindly check the yellow marked area.
Hi @nazarvbava,
The issue has been fixed by our team; it should now work fine for you.
Thanks issue is fixed
Hi @nazarvbava,
As your issue has been resolved, we’d appreciate it if you could share quick feedback on the support received:
Thank you for your time.
