Edit a Forum Entry
Status: Closed · Asked by Raymond St Clair on · 0 views
Hello there,
Thanks for contacting us.
Unfortunately, the posted comments cannot be edited in the Forum. You can post a new updated comment below the original comment.
Adeel Akhtar
🌐 Pabbly.com
Pabbly Support:
Hello there,Thanks for contacting us.Unfortunately, the posted comments cannot be edited in the Forum. You can post a new updated comment below the original comment.Thanks & Regards,Adeel Akhtar🌐 Pabbly.com
Is there a logical reason behind that?
Hello there,
I am afraid the feature to edit the comment was not added deliberately to avoid confusion by the Technical Team, as the New Forum was launched only a few days ago. The old forum has that feature. Further, there is no problem if you add another comment with the updates you want to post.
Adeel Akhtar
🌐 Pabbly.com
