Feature Request - Please add integration with Pipeline pro
Status: Open · Asked by adityawaliawalia on · 0 views
adityawaliawalia — Question ·
Please add a integration with Pipeline pro - its same as go high level and has same features would be great if you can add integration with it https://www.gopipelinepro.info/
Please look into it
Hi @adityawaliawalia,
If you want this application to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://roadmap.pabbly.com/b/Integration-Request
Our integrations team will look into your request and, if possible, add the desired application to Pabbly Connect.
Fagun Shah — Reply ·
Please look into it
PipelinePro is just a white label version of GoHighLevel, you can search LeadConnector in pabbly workflow to integrate. It is exactly the same software and will work fine.
