How to connect Wrike to Pabbly
Status: Open · Asked by gregv on · 0 views
gregv — Question ·
Hi!
I'm trying to connect Wrike to Pabbly so that when new tasks are created in Wrike, it will clean up the description so we can pass to Asana. (We're doing a migration to Asana but clients are still using Wrike forms to create requests). I've connected Wrike but I cannot get past this screen. I've tried creating a task manually, using a form, etc. but nothing seems to get the response to fire.
When I connect Asana, the projects list is empty under "Create New Task". I can't type in the project ID manually into the field manually either.
Hi @gregv,
Please disable your current workflow and create a new one from scratch without cloning it. Then, try setting up Wrike as the trigger step in the new workflow.
You’ll need to create a new task in order to capture it in your trigger step.
