I'm having trouble with captions when posting on Instagram for business.
Status: Open · Asked by stevenphan on · 0 views
stevenphan — Question ·
Even though I've switched to HTML, it frequently gets stuck with the \\n character. Is there a Node.js plugin that handles regular captions well?
Caption:
?? These Fish Sauce Fried Chicken Wings at Pho 3B & More hit with bold flavor and pure comfort vibes. Crave-worthy, satisfying, and unforgettable.
? Come taste the excitement!
_______________________
☎️ (559) 372-7034
? 1424 N Ben Maddox Way, Visalia, CA 93292
#Pho3B #TasteVietnam #GrandOpening #PhoTime
#Visalia
#VisaliaCA
#VisaliaFood
#VisaliaEats
#Tulare
#TulareCA
#TulareFood
#CentralValleyEats
#CentralValleyFood
#VisaliaFood #TulareFood #Pho #VietnameseFood #Pho3BMore #VisaliaRestaurants #FromBowlToSoul
Hrishabh Tiwari — Reply ·
Hello @stevenphan ,
We appreciate you reaching out to Pabbly Support!
Could you please provide more details about your specific use case? Additionally, it would be helpful if you could share the URL of the workflow you've created so that we can thoroughly review it and provide further guidance.
Please be aware that to assist you effectively, we may need to access your Pabbly Connect account. If you're comfortable with this, please grant us permission by stating in your next email: "You have my permission to log into my Pabbly Connect account, and edit workflow {If required}. Here is the registered email address associated with it."
Hello @stevenphan
Thank you for sharing the workflow link and additional details.
We have escalated this issue to our development team for further investigation. They are currently testing the caption handling internally to identify the exact cause of the unwanted characters appearing in the Instagram post.
During this testing phase, you may notice duplicate posts being created in your Instagram account. These are generated as part of the debugging process.
Please make sure to delete any duplicate posts that may appear.
We’ll update you as soon as we have more information.
Thank you for your patience and cooperation.
Hello @stevenphan,
Thank you for your patience.
Our team has tested the Instagram step and confirmed that it is working as expected in the old workflow builder. The issue with the unwanted characters does not occur there.
Could you please try testing the same workflow using the old workflow builder and check if the captions are posted correctly?
Once you’ve tested it, let us know the outcome so we can assist you further if needed.
Looking forward to your update.
