INSTAGRAM STORY POST PROBLEM
Status: Open · Asked by Bananajuice2002 on · 0 views
I just wanted to ask if any of you know how to create an image using OpenAI (DALL·E 2 or DALL·E 3) in a specific dimension that works for Instagram Stories. I don’t have any issues running the workflow, but the problem is with the format of the generated image.
Instagram requires a 9:16 ratio for Stories, but DALL·E typically outputs images in fixed formats like 256×256, 512×512, or 1024×1024. When I try to use these in a Story, Instagram crops the image badly—cutting off important parts and making it look awful.
To my understanding, the proper size I need is something like 1024×1920 or close to that 9:16 ratio.
Do you know if there’s a way to force DALL·E to generate image in the right ratio/or add another application to change ratio for the right one? Or a best practice for resizing or prepping them properly for Stories without losing visual quality?
Thanks in advance for any advice! ?
URL: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZjMDYzMzA0MzI1MjZmNTUzZDUxMzUi_pc
Hello @Bananajuice2002,
We have made a few changes to your action step and it seems to have generated a publicly accessible image URL in the required ratio. Please check and let us know if it works fine for you.
it has worked, thanks
You can find experts through our Pabbly Connect Experts and Consultants forum and in our Facebook group.
