JSON Selecttransform Integration Problem
Status: Closed · Asked by marlon1337 on · 0 views
Hi guys,
I can't figure out how to transform a json with the selecttransform integration.
The template works at https://selecttransform.github.io/playground/ but when pasting it to Pabbly I get an error.
Here is what works on the selecttransform playground:
var data =
[{"id":1000470,"name":"Rainglide One 70cm","product_id":230412,"variation_id":0,"quantity":2,"tax_class":"","subtotal":"42.61","subtotal_tax":"9.37","total":"42.61","total_tax":"9.37","taxes":[{"id":63,"total":"9.373443","subtotal":"9.373443"}],"meta_data":[{"id":1004807,"key":"_unit","value":"","display_key":"_unit","display_value":""},{"id":1004808,"key":"_unit_base","value":"","display_key":"_unit_base","display_value":""},{"id":1004809,"key":"_unit_product","value":"","display_key":"_unit_product","display_value":""},{"id":1004810,"key":"_item_desc","value":"","display_key":"_item_desc","display_value":""},{"id":1004811,"key":"_defect_description","value":"","display_key":"_defect_description","display_value":""},{"id":1004812,"key":"_delivery_time","value":"","display_key":"_delivery_time","display_value":""},{"id":1004813,"key":"_min_age","value":"","display_key":"_min_age","display_value":""}],"sku":"RO70","price":21.3032785,"image":{"id":"230396","src":"https:\/\/rainglide.com\/wp-content\/uploads\/2025\/01\/Rainglie-One-Shop-Picture.jpg"},"parent_name":null},{"id":1000471,"name":"Rainglide One 65cm","product_id":230411,"variation_id":0,"quantity":3,"tax_class":"","subtotal":"63.91","subtotal_tax":"14.06","total":"63.91","total_tax":"14.06","taxes":[{"id":63,"total":"14.060164","subtotal":"14.060164"}],"meta_data":[{"id":1004823,"key":"_unit","value":"","display_key":"_unit","display_value":""},{"id":1004824,"key":"_unit_base","value":"","display_key":"_unit_base","display_value":""},{"id":1004825,"key":"_unit_product","value":"","display_key":"_unit_product","display_value":""},{"id":1004826,"key":"_item_desc","value":"","display_key":"_item_desc","display_value":""},{"id":1004827,"key":"_defect_description","value":"","display_key":"_defect_description","display_value":""},{"id":1004828,"key":"_delivery_time","value":"","display_key":"_delivery_time","display_value":""},{"id":1004829,"key":"_min_age","value":"","display_key":"_min_age","display_value":""}],"sku":"RO65","price":21.303278666666667,"image":{"id":"230396","src":"https:\/\/rainglide.com\/wp-content\/uploads\/2025\/01\/Rainglie-One-Shop-Picture.jpg"},"parent_name":null},{"id":1000472,"name":"Rainglide One 60cm","product_id":230410,"variation_id":0,"quantity":1,"tax_class":"","subtotal":"20.48","subtotal_tax":"4.51","total":"20.48","total_tax":"4.51","taxes":[{"id":63,"total":"4.506394","subtotal":"4.506394"}],"meta_data":[{"id":1004839,"key":"_unit","value":"","display_key":"_unit","display_value":""},{"id":1004840,"key":"_unit_base","value":"","display_key":"_unit_base","display_value":""},{"id":1004841,"key":"_unit_product","value":"","display_key":"_unit_product","display_value":""},{"id":1004842,"key":"_item_desc","value":"","display_key":"_item_desc","display_value":""},{"id":1004843,"key":"_defect_description","value":"","display_key":"_defect_description","display_value":""},{"id":1004844,"key":"_delivery_time","value":"","display_key":"_delivery_time","display_value":""},{"id":1004845,"key":"_min_age","value":"","display_key":"_min_age","display_value":""}],"sku":"RO60","price":20.483607,"image":{"id":"230396","src":"https:\/\/rainglide.com\/wp-content\/uploads\/2025\/01\/Rainglie-One-Shop-Picture.jpg"},"parent_name":null}]
var template = {
billable:{
products: {
"{{#each this}}": {
qty: "{{this.quantity}}",
unit_price: "{{this.price}}"
Here is the error in pabbly. I tried pasting it in many ways. with "" for every value, deleting breaks and spaces adding three {{{, with template= with var = template... etc. All possible combinations, nothing works.
In the end I need the transformed JSON to be the raw data in a custom API POST. The transformed JSON for the JSON above will look like this:
"billable": {
"products": [
"name": "Rainglide One 70cm",
"qty": 2,
"unit_price": 21.3032785
"name": "Rainglide One 65cm",
"qty": 3,
"unit_price": 21.303278666666667
"name": "Rainglide One 60cm",
"qty": 1,
"unit_price": 20.483607
}Inserted here:
I appreciate any help. Thank you!
Hi @marlon1337,
Hello @marlon1337,
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY5MDYzZjA0MzA1MjZhNTUzNTUxM2Ii_pc
We have added a Select transform JSON action step as step 4 of your workflow which seems to be working fine please refer to the attached image for more info.
@Preeti Paryani
Thanks, but it still is not the same as the result from selecttransform as it should be.
The correct result is:
"billable": {
"products": [
"qty": 2,
"qty": 3,
"qty": 1,
}right now the result after your change is just:
[{"name":"Rainglide One 70cm","qty":2,"unit_price":21.3032785},{"name":"Rainglide One 65cm","qty":3,"unit_price":21.303278666666667},{"name":"Rainglide One 60cm","qty":1,"unit_price":20.483607}]I actually expect the same outcome as on the playground page. As this is what I am aiming on, as this is the form which is required.
//Edit: And it is just working for the step you changed. When I try to replicate this step (without copying it) I again see the same error with 'invalid request format'. Because I have to replicate this step in another workflow. This workflow is just to test around.
Hello @marlon1337,
Please check now the result should be as the expected one. Also, if you want to use the same action step in another workflow you can simply copy the action and paste it below the required step.
@Preeti Paryani
Thank you, almost there. I would need the exact outcome as in the playground. Right now I still have the [ ] at the beginning and the end which would then require another text regex transformation step from me. Would you be able to adjust the outcome to exactly to what is shown on the selecttransform playground? It's just the [ and ] at the beginning and end which should not be there.Thank you!
We have added Python code to your workflow to remove the outermost square brackets. Please check Step 5 of your workflow.
@ArshilAhmad I would like to use a free workflow step like text transform with regex to remove the outside brackets. However Regex like /^\[(.*)\]$ which works when testing on Regex test tools is not returning anything in pabbly. I tried multiple regexes which should return the same capture groups. Best would that I just get exact the same output as selecttransform gives, then the problem would be solved. An extra non free workflow step is not an option as I want to run this task a lot and Regex or selecttransform should work correctly.
Hello @marlon1337,
We’ve assisted you with the best possible solution available within the current limitations. However, if you're looking for a more personalized workaround that strictly uses a free step, we recommend hiring an expert who can guide you with a tailored approach specific to your use case.
You can find experts through our Pabbly Connect Experts and Consultants forum and in our Facebook group.
@Preeti Paryani this is not okay. The problem only occurs because selecttransform is not working correctly as it should. And Regex is also not working correctly. This is obviously a bug/not good made integration.
Hello @marlon1337,
We’ve helped configure the Select Transform, and it’s returning the expected result—so it does seem to be functioning as intended. However, please note that this particular step is not part of the free steps.
Regarding the Regex, the current implementation supports basic use cases. The specific requirement you're aiming for goes a bit beyond what’s currently supported, so we may not be able to fully accommodate that at the moment.
That said, we recommend continuing with the Select Transform action, as it is successfully returning the desired response.
@Preeti Paryani no, the actual result of selecttransform is without [ ] .
This is the correct result and there should not be any bracket or anything else appearing. It's the whole point of using selecttransform to get exactly the return to fit the template.
Correct result for the template as also shown at the playground:
"billable": {
"products": [
"qty": 2,
"qty": 3,
"qty": 1,
}Hello @marlon1337,
We have added two Text Formatter actions to your workflow to get the desired result, refer to the attached image for more info.
The step 4 is now returning the correct response.
Thank you!
Hello @marlon1337,
Thanks for the update!
