need help with form subbmition
Status: Open · Asked by mistrysameer on · 0 views
mistrysameer — Question ·
workflow
1. User enters name in a form and submits it
2. We verify the name against a list
3. if name is not present in list we add the name to the list and we forward it to next step and send a whats app msg success
4. if the name is already in the list then we say below the form submit button " Name Already Exixts" and do not forward the name to next step and send a whats app msg failed
Hi @mistrysameer,
Please elaborate a bit more on the applications involved in this workflow, such as which form you are using in the trigger step and which application the list you are referring to is in.
Also, could you elaborate a bit more on what exactly you mean by this?
mistrysameer — Reply ·
I am making a website where user gets trial access for a service.
User enters a username and gets 3 days access
The website makes collects the userme and forward it to papply via webhook.
After which it should trigger a verification
1. If the username is not in a list of previously accessed user name then we give 3 days access vis a api call to my server ( server is setup and ready ) and add the user name to a list and send a whats app msg”Thankyou”
2. If the username is present in the list of previously accessed user name then we send a whats app msg “You have already acces trial”
Hello @mistrysameer
Could you please let us know where the list of usernames is maintained and which application is being used for this purpose This information will help us assist you more effectively.
If you have already set up a workflow to achieve this use case, kindly share the workflow URL with us. This will allow us to review it and suggest any necessary corrections.
Names will be saved in google sheet
I am flexible with any app I just need the workflow
Hello @mistrysameer
I have created a reference workflow that aligns with your use case. You can review it and make further adjustments as needed.
Here are the details:
Please feel free to check it out and let me know if you have any questions or need further assistance.
