open ai assistant - need help with integration
Status: Open · Asked by adityawaliawalia on · 0 views
Hi i have a guy who send data from
webhook to go high level and then creates a open ai chat under a specific assistant and then send it back to go high level
below is a example of his workflow from make.com i am so dissapointed with pably that inspite having a lifetime plan i am forced to use make.com for this integration
Please tell me how to set it up properly since i cant find below setup on open ai connection
Hello @adityawaliawalia,
Thank you for sharing your feedback with us.
We have escalated your request to our team, and if feasible, we will certainly consider adding this feature to our platform.
We had the ability to use an assistant before in Pabbly Connect but it was taken away. It's confusing that so many of the recent youtube videos use the term "agent" but there's no assistant functionality. What am I missing?
They created a custom app called AI Assistant, which actually uses OpenAI assistant on the backend.
This should be possible using AI Assistant app actions or via OpenAI app's Custom API call action(harder way if you don't know APIs). But overall it should work.
I don't think I'm following. Are you saying that within a Pabbly Connect workflow, I can still access OpenAi assistants that I created before? That's the functionality that I'm talking about.
Pabbly team moved all Openai Assistant actions to an app called AI Assistant.
Thank you...that helped. It seems that we do have to create them again (and therefore only accessible through Pabbly) but the functionality is there. I really appreciate your response.
Glad that my answer helped you.
