[Pabbly + Pipedrive] Problem with response
Status: Open · Asked by SupportHubstrat on · 0 views
SupportHubstrat — Question ·
Hi, we're having a problem with the response on some steps.
Specifically, the response doesn't return the individual fields, but a single result, and this is causing problems with field matching.
Why does this happen?
Hi @SupportHubstrat,
It appears that you captured the response in Advanced format. We’ve now captured the response in Simple format, and it seems to have fixed the issue.
Arshil Ahmad
? Pabbly.com
?Rate your support
