Phone number field not working correctly
Status: Closed · Asked by danielsan on · 0 views
danielsan — Question ·
I can't add clients' phone numbers using basic country codes.
A phone number formatted like this: +44123456789 doesn't work.
Is that a bug or is it designed this way?
Seems like a pretty big oversight
PabblyMember2 — Reply ·
Hello Daniel,
Kindly let us know from where you are adding the phone number like from a checkout page or while manually creating a customer/invoice or in the client portal.
danielsan — Reply ·
When adding clients manually in the customers section
Hello Daniel,
We have added the validation.
Kindly check once again and try to add the phone number in the fields.
danielsan — Reply ·
it is working now! thanks for the fix!
