Problem connecting pipelines of pipedrive
Status: Closed · Asked by mrivas on · 0 views
Hi Guys, my problem is that I select a pipeline then trying to select the stage of tat pipeline, I CON NOT SEE THE stages of that pipeline, an then the leads go to the last used pipedrive, it is very strange
I was wondering why I can not see the stages of the selected pipedrive.
Then the problem is that the leads go to the first pipedrive instead of going to the selected pipedrive
I wouls appreciate any recomendation
best regards,
Mario
Hi @mrivas,
Sure here is, many thanks
Hi @mrivas,
If you only enter the Stage ID, it will still be added to Pipedrive, as the stage is interlinked with the pipeline in Pipedrive. Please try using the action without the Pipeline ID and let us know if it works fine for you.
Hi Preeti, how can I know the stage ID, where can I get it?
You can try using the 'Get All Stages' action step to fetch the Stage ID.
Thanks you @ArshilAhmad It works!
Thank you for the update. We are glad we were able to help.
As your issue has been resolved, we’d appreciate it if you could share quick feedback on the support received:
If you like our product, please consider leaving us a Google review. Your feedback helps others see how Pabbly can support their business.
Thank you for your time.
