Shopify Variant Inventory Issue
Status: Open · Asked by grantandrew on · 0 views
Hello - I'm updating Shopify inventory from a webhook using Shopify Legacy (didn't see an inventory update step available in V2). This works great for regular products - however, I cannot find a way to successfully update inventory on variants. When I load an option manually, it will show the names of the variants in the dropdown and when submitted, those work, however, if I paste the number in manually, or I map it from the webhook, both of those methods fail.
You can see in the Workflow and use the variant ID 44844524404780. I can transform or format the data differently - including by name if necessary, but I don't see that any of those are working.
Feel free to test the workflow as necessary. Thank you!
Hello @grantandrew,
Thanks for reaching out. Upon checking, it seems that the variants are not appearing in the dropdown in the new UI due to some issue, which we have escalated to the technical team. In the meantime, you may use the classic version to set up your workflow.
Hello @grantandrew,
This is to inform you that the issue you were facing with the listing of the variants under the new UI has now been fixed.
