Workflow stops half way through with no error
Status: Open · Asked by wibbler on · 0 views
This workflow has been working for months completely fine. It stops after the delay is completed.
Two examples of tasks stopping half way:
IjU3NjUwNTZlMDYzZTA0M2M1MjZmNTUzNDUxM2I1MTYxNTQzMjBmMzci_pc
IjU3NjUwNTZlMDYzZTA0M2M1MjZlNTUzYzUxMzE1MTY3NTQzNzBmMzci_pc
Hello @wibbler,
Thank you for bringing this to our attention.
We’ve escalated the concern to our technical team and will keep you updated as soon as we receive any further information.
We appreciate your patience in the meantime.
thank you
Hello @wibbler,
Upon checking with our team, we’ve concluded that the issue might have been caused by a recent deployment, which may have affected the delay and caused it to stop unexpectedly.
We recommend re-executing the entire task history, as this should help trigger all the actions following the delay.
If you encounter this issue again, please share the relevant task histories with us so we can investigate further.
